Компания Beston Group Co., Ltd.
A Totally Continuous Tire Pyrolysis Plant Can Work for a long time Without Interruption
Transport equipment, cars, trucks or others need rubber tires for smooth movement and they have a tendency to get worn out after long use. The waste tires were in earlier days placed into landfills where they took quite a long time to decompose and generated environmental problems. It is now possible to use tire pyrolysis plants to convert the waste tires into oil, carbon black, and hydrocarbon gas, all byproducts which have a use. This may reduce waste in landfills and save environmental surroundings.
The whole process of Pyrolysis
The whole process of pyrolysis chemically decomposes the organic materials within the tire, mainly rubber, at extremely high temperatures and does so in the absence of oxygen and under pressure. These could be up to 430°C (800°F). This changes the physical plus the chemical composition of your waste tires and is a process that should not be reversed. pyrolysis
The Makeup of any Pyrolysis Plant
The key component of a pyrolysis plant is its reactor when the waste tires are heated using fuel, like wood, gas, or coal, and the like. With this heating, oil gas is first produced and is needed to be brought to a condenser which will liquefy the gas directly into oil that needs to search for a oil tank. The gas that is not condensed is led into the reactor to do something as fuel for burning. When the reactor cools down carbon black is produced and must be removed. Steel, often utilized in radial tires is likewise an area of the residue after burning. More details on our website here: https://bestonasia.com/tire-pyrolysis-plant-cost/.
A pyrolysis plants may also be designed being a fully continuous tire pyrolysis plant that makes the byproducts without any need for cooling the reactor.
Continuous Tire Pyrolysis Plants
A fully continuous tire pyrolysis plant design allows all operations from the loading of your tires to producing the many byproducts to get completed without the interruption. Such plants will work all twenty-four hours a day and throughout the year, provided that you will discover a continuous flow of raw material - waste tires. It functions as an assembly line that constantly takes inside the raw product and creates a constant flow of oil, carbon black and steel.
For continuous feeding, waste tires must be shredded and made right into a smaller size. The tires are fed in to a shredding machine and cut to a size of a couple of". The shredding process also separates out the steel in the tires and this may be retrieved magnetically from these shredders. The shredded material is automatically conveyed on the reactor , where heat is definitely being generated. The oil gas finds it way to connected condensers where it is actually changed into liquid oil that may be then kept in tanks. Carbon black is produced at certain temperatures and automatically retrieved. Multiple reactors are used with the internal rotating system and heated with hot air which utilizes other fuel or even the oil gas for heating.
Plants from Beston Group that work well continuously are controlled by computers and will be programmed, for those operations from feeding, burning and byproduct retrieval of carbon black, fuel oi and steel.
pyrolysisplant, tirepyrolysisplant, wastetirepyrolysisplant,
